› Fora › ASTRO-FORUM › TEKNIK – TILBEHØR › Pixelstørrelse, betyder det noget?
- Dette emne har 50 svar og 8 stemmer, og blev senest opdateret for 11 år siden af morten. This post has been viewed 746 times
17. februar 2013 kl. 22:08 #97638
Pixelværdien har ikke nogen principiel betydning, kun præcisionen. Vil lige citer Ron Wodaski i stedet for at rode mig ud i noget sludder:
One more consideration. Now that you have all those nice optimal sub-exposures, how do you combine them – sum or average?Simple answer: There is no difference! (This illustrates how non-intuitive noise really is…)
What is an average? It’s simply a scaled sum! The only potential problem you run into is if the precision in your sum is such that the scaling reduces the precision. Most CCD cameras only have 14-15 bits of dynamic range, but you are using no smaller than 16-bit numbers to contain the scaled result. Only if you have enough images to generate more than 16 bits of information do you need to worry. And even then the solution is extremely simple: just switch to floating point or 32-bit integers to save your scaled result – then there is no difference whatsoever between a sum and an average.
As it happens, as long as you retain the _real_ precision of your data (which is smaller than the 16-bit container your software typically uses), an average is the gold standard for lowest noise. (except for outliers, which gets us into a WHOLE other area of discussion and now my fingers are tired.)
17. februar 2013 kl. 22:24 #97640
michaelrDeltager- Super Giant
Hej Jesper
Jeg tror det er alt for et generelt udsagn. Hvis vi taler om svage objekter er hardware binning uden tvivl stadig relevant, også selv om kameraerne er blevet bedre. Jeg vil påstå, at ved f.eks. Emberson 1, som vi er nogle stykker, der vi gå efter, er der store gevinster ved at anvende binning, hvis muligt. Men det kan jo komme an på en prøve. Skal vi ikke designe nogle testoptagelser, som vi kan gennemføre?Med QSI 583 på C14 @f7 ville jeg naturligt binne 2 gange i Ha og måske 3 gange i “farvekanalerne” OIII og SII.Hvordan kan vi bedst teste effekten af binning?BhMichael17. februar 2013 kl. 22:28 #97641
edbbobDeltager- Super Nova
Jeg skal lige tilbage til computeren, så skal jeg prøve at lave et grafisk eksempel
Sagde han og smed iPad’en på divaneseren… Som gadgetfreak er det godt man ikke levede i stenalderen.
17. februar 2013 kl. 22:38 #97642
Hej Michael,
Jeg mener bestemt også at det har en betydning om man soft eller har binner. Den bliver bare mindre hele tiden fordi kameraerne bliver bedre, men forskellen er der stadig.Det jeg gerne vil frem til er hvis man for eksempel står overfor valget mellem et ældre DSLR (350D) med store pixels og et af de nye med små pixels (1100D). Eller måske skulle man vælge mellem et CCD kamera med ICX694 og et andet med en ældre Kodak chip med store pixels. I de situationer ville fordelene ved den nye teknik langt overskygge ulempen ved at skulle softbinne. Der ville man gøre sig selv en bjørnetjeneste ved at gå efter store pixels.Problemet ved at teste er at det altid er overskyet. Vi skulle jo også have testet betydningen af sub tid på svage objekter. Men jeg må jo indrømme at når det så endelig bliver klart vil jeg sgu hellere bare have nogle billeder i kassen fremfor at lave tests
Jesper 2013-02-17 21:46:56 17. februar 2013 kl. 22:53 #97644
Det kommer liiige til at tage lidt tid.
Jeg er selv i syv sind i øjeblikket. Valget står mellem Kaf-8300 og ICX694. Sony chippen er nemmere/billigere at arbejde med i forhold til størrelsen af ens korrigerede felt.
Mht vejret, så jeg månen gennem disen lige før! Vildt nok! Ellers kunne det være der snart var basis for, at lave en lille dansk enklave på La Palma.
18. februar 2013 kl. 00:18 #97650
Hej Jesper
Jeg er endnu engang kommet udenfor emnet med pixel størrelse
, så jeg har oprettet en anden tråd omkring kombinering af stacks med forskelligt antal subs.Sorry!
Vh
Morten
EDBBOB 2013-02-18 00:57:35 18. februar 2013 kl. 09:34 #97662
wiebenDeltager- Nova
Spændende emne. Jeg år selv med samme overvejelser som EDBBOB – KAF8300 vs Sony ICX694. Alt tyder på jeg vælger Sony’en, men ville dog ønske KAF’en havde Sony’ens egenskaber.
Jeg er dog ved at være overbevist om at den lave støj, samt mulighederne for binning opvejer prisen ved et lille felt..
Jesper har jo tydeligt bevist at små pixels kan give flotte resultater selv under en dansk himmel.
Se også dette eksempel taget med den lille Sony ved 1,6 meters brændvidde og 4,5 timers eksponering:
Bubble
Wieben 2013-02-18 08:36:56 18. februar 2013 kl. 10:30 #97665
Hej Heine,
KAF8300 er jo også en god chip og den giver et større felt, så det kan være svært at vælge mellem de to. Jeg ville også ønske at Sony lavede nogle større mono-chips med samme gode egenskaber. Men det er måske lettere sagt end gjort.18. februar 2013 kl. 11:14 #97667
Mogens.BildsøeDeltager- Nova
Jesper wrote: Hej Mogens, Jeg må indømme at jeg ikke helt ved det med brønddybden. Jeg gik ud fra at, i hvert fald hardwarebinning ville resultere i samme brønddybde. Jeg må også indrømme at jeg mest tænker på “pretty pctures” og ikke så meget på den mere videnskabelige del
Nåja, synes nu ikke det kun har betydning for det mere “videnskabelige”, som du kalder det
; fandt lige et par svar på mit spørgsmålet vedr. hardware-binned pixels brønddybder:f.eks.:ellerSå facit er, som jeg læser det, at den oprindelige brønddybde på de ubinnede pixels ej heller må overskrides under eksponeringen efter binning.Mogens B 2013-02-18 10:27:28
18. februar 2013 kl. 11:39 #97669
Mogens B wrote:
Så facit er, som jeg læser det, at den oprindelige brønddybde på de ubinnede pixels ej heller må overskrides under eksponeringen efter binning.Det tror jeg du har ret i, men vil den maksimalt tilladelige eksponeringstid ikke være ens for chip A i 1×1 og chip B i 2×2?18. februar 2013 kl. 11:52 #97672
@Mogens: Tak for link. Dem skal jeg have læst ordentligt igennem, når der kommer ro på senere.
@Jesper: Havde du ikke et kamera med en Kaf-8300, før du fik dit 460, eller er det mig som husker forkert?
Vh
18. februar 2013 kl. 12:15 #97674
Vh
Nej jeg har et Artemis 11002 med KAI-11002 chippen. Det er en 24×36 chip så man kan selvfølgelig ikke sammenligne den direkte med ICX694, men jeg kan sige så meget at pixel-SNR subjektivt er ens med de to chips på trods af at den gamlke har 4x så stort lyssamlende areal pr pixel. Målingen er foretaget hved hjælp af mit øje/hjerne, som er et ufejlbarligt måleinstrument …Jeg skal skynde mig at sige at KAF-8300 er betydeligt bedre end KAI-11002 på støj og QE, så den erfaring kan ikke overføres til den. Ikke desto mindre havde Heine jo en link der viste at ICX694 faktisk når lidt dybere end KAF-8300, på trods af de mindre pixels.18. februar 2013 kl. 12:17 #97675
@Jesper: Mit første eksempel er dårlig valgt
; det er vist svært at få eens brønddybde i pixels med forskellig størrelse (areal). Ser vi på den samme chip, når vi det ulineære opmråde efter samme eksponeringstid på de binnede og de ubinnede pixels. Igen, som jeg forstår det! Angives fotonflux som antal e pr. my^2 pr s, og kendes brønddybde samt pixelareal, kan man vel sjusse og sammenligne også chips med forskellige pixels? Men humlen er, at hardware-binning ikke ændrer på max exp tiden for den (samme) binnede og ubinnede chip.
@ Morten:
Mogens B 2013-02-18 11:22:38 Hilsen Mogens B.
18. februar 2013 kl. 19:01 #97698
mortenDeltager- Super Nova
Spændende diskussion. Jeg har skrevet lidt om hard og softbinning tidligere. Mine målinger med KAF8300 chippen bekræfter meget præcist ovenstående hamamamatsu (tror jeg det var) link.
Ved bin 1×1 er brønddybden 25709 e-, støjen er 7.1 e-. Dynamikområdet er brønddybden divideret med støjen og er altså 3609 ved bin 1×1.Ved (hard) bin 2×2 er brønddybden 63046e- og støjen er 11,3 e-. Dymanikområdet er 5579. Dette svarer ret godt til, at serieregistrene ikke kan klare mere end det dobbelte af de parallelle registre, og at opsamlingsnoderne ikke kan mere end 50% yderligere. KAF8300 er muligvis lidt dårligere end det anførte, og det er måske årsagen til den blooming der ses ved binning, og som er beskrevet nedenfor.Ved hard bin 2×2 kan altså ikke opnås den firdobbelte brønddybde, kun godt den dobbelte OG udlæsningsstøjen er 60% højere end ved bin 1×1.D.v.s. det er ikke korrekt at udlæsningsstøjen er den samme ved bin 1×1 og ved bin 2×2Dette er bekræftet af flere andre, og kan findes på QSIs yahoo tech gruppe og andre steder. Mht Sonys ICX694 chip har jeg også målt udlæsningsstøjen i bin 1×1 og bin 2×2. Også her er den højere i bin 2×2 end i bin 1×1, jeg kan dog ikke lige finde målingerneVed soft bin 2×2 (på simpleste vis bare ved summation) får vi en brønddybde på fire gange brønddybden ved bin 1×1 (hvis man sørger for at anvende 32bit fits til resultatbilledet). “Støjen” er to gange udlæsningsstøjen i bin 1×1. (Støjen på en sum af n uafhængige variable er kvadratrod(n) gange støjen på den enkelte). D.v.s. vi får en brønddybde på 102836 og en søj på 14.2. Dynamikområdet bliver 7218.Altså ved softbinning får man større brønddybde og (dermed) større dynamikområde end man gør ved hardbinning.Dertil kommer at 8300 chippen opfører sig dårligt ved hard binning fordi dens serieregistre bloomer. Også det er der skrevet om tidligere.Konklusion 1: Man kan ikke regne med, at hardbinning fordobler brønddybden og bevarer udlæsningsstøjen uændret.Konklusion 2: Med KAF8300 får man 26% højere støj pr pixel ved at soft binne end ved at hard binne. Til gengæld får man knapt den dobbelte brønddybde med soft binning i forhold til hardbinning, og dermed 30% større dynamikområde.Konklusion 3: Valget mellem små og store pixels afhænger af hvordan de små opfører sig når der binnes. Med en KAF8300 er det min erfaring at hard binning er en dårlig ide. I hvert fald med mine (febrile) aperturer på 250-350mm får man dårlige stjerner med hardbinning. Så vidt jeg har forstået har Sonys ICX694 chip ikke tilsvarende dårlige egenskaber ved binning, jeg er ikke klar over hvad dens serieregistre kan klare, men så vidt jeg husker får man heller ikke den fulde brønddybde ud af hard binning med den chip.morten 2013-02-18 18:06:11 18. februar 2013 kl. 19:43 #97699
Spændende oplysninger. Det er interessant at høre at der er fordele og ulemper ved både hard og softbinning og at det ikke er så ligetil som man skulle tro. Jeg valgte jo at se bort fra udlæsninsstøj og brønddybde i oplægget, som har et lidt andet fokus, men det var nok lige så meget på grund af min uvidenhed. Det er altid godt at få så mange facts på bordet som muligt.
Du skriver: “Valget mellem små og store pixels afhænger af hvordan de små opfører sig når der binnes”. Det er jo rigtigt men det jeg også gerne ville fremhæve var tendensen til at de nye forbedrede udgaver af CCD og især CMOS chips, samtidig får mindre pixels. Det er sikkert på grund af megapixel ræset i dagslyskameraerne. Der kommer ikke rigtig tilsvarende gode chips med større pixels. Hvis der gjorde det ville valget være let nok, men som det er, er små men gode pixels et bedre valg end store men dårlige IMO. -
- Emnet 'Pixelstørrelse, betyder det noget?' er lukket for nye svar.
