Ny Sky-Watcher Montering
› Fora › ASTRO-FORUM › KØB & SALG, FORHANDLERNYT › Ny Sky-Watcher Montering
  • Dette emne har 8 svar og 7 stemmer, og blev senest opdateret for 11 år, 5 måneder siden af tomvictor. This post has been viewed 35 times
  • #89684
    Astro Optics
      Sky-Watcher lancerer nu deres nye AZ-EQ6GT Alt-Azimuth/Equatorial Computerised Goto Mount.
      En montering som både kan bruges i AZ- og EQ opsætning.
      AZ opsætning
      EQ opsætning:
      Data: (fra OVL hjemmeside):
      The Sky-Watcher AZ-EQ6GT is an exciting evolutionary development of the hugely successful NEQ6 PRO.
      The AZ-EQ6GT is a dual purpose, fully functional computerised heavy-duty Go-To/Tracking astronomical mount in both Alt-Azimuth (AZ) and Equatorial (EQ) modes.
      Supplied with a Synscan handset with dual AZ/EQ firmware, it can automatically find and track over 42,900 celestial objects from its database.
      In EQ mode, the AZ-EQ6GT is designed for either visual use or precise astro-imaging.
      In AZ mode, it is primarily intended for visual use, and in this mode, two telescopes can be mounted simultaneously in parallel.
      A great feature of the AZ-EQ6GT is the patented dual-encoder technology. This allows the telescope to be moved manually in either axis without the mount losing its positional information. This gives the user enormous freedom, convenience and flexibility during observational sessions.
      The Sky-Watcher AZ-EQ6GT…..a new legend is born!!
      SPECIFICATION
      Payload Capacity: 25kg (EQ and AZ modes)
      Tracking Accuracy: 0.1436 arc second
      Go-To Capability: EQ and AZ modes
      Synscan Handset Database: over 42,900 celestial objects
      Tracking Speed: sidereal, solar & lunar rates
      Tracking Mode: EQ or AZ, dual or single axis
      PEC control in EQ mode
      Autoguider Port : Yes
      DSLR Electronic Shutter Release Port : Yes
      Motor Type: DC12V stepper motors
      Patented Dual-Encoder design allows manual movement without losing positional information
      Polar alignment: via software control or supplied polar scope
      Alignment methods: 1, 2 or 3 star alignment (EQ) / brightest star or 2 star alignment (AZ)
      Telescope Connection: 2 x dual-fit saddle plates supplied accepting 45mm & 75mm dovetail bars
      RA/DEC Worm Gears: D=92.5mm, 180 teeth, brass
      RA/DEC Axes: D=40mm, steel
      Tripod: 2” Stainless Steel
      Counterweights supplied: 2 x 5kg
      Counterweight Bar: 25mm Diameter
      Mount Body Weight: 15.4kg, Tripod Weight: 7.5kg
      Power requirement: 12V DC 3A (Sky-Watcher 17Ah Power Tank recommended)
      Note: Two 5kg Counterweights supplied, not four as shown in main picture
      Forventet levering i løbet af november 2012.
      Pris: kr. 16.000 inkl. moms
      Mogens Zachariasen
      http://www.astro-optics.dk
      Forhandler og importør af astronomisk udstyr til private, til skoler og til EU siden 1995.
      Celestron, Sky-Watcher, Baader Planetarium, Explorer Scientific, ADM Accessories,
      Starlight Xpress, Atik Cameras, ZW Optical, Lunt Solar Filters, Daystar Filters.
      #89697
        Interessant! En videreudvikling af NEQ6 Pro havde jeg ikke forventet skulle komme nu, men det er jo måske naturligt når jeg tænker mig om.
        Er der nogen information/måling af PE (med/uden PEC) på denne? Er den ens med NEQ6 Pro eller forbedret?
        #89699
          Det ser ud til at være en spændende opdatering. Encodere og en tykkere vægtstang er noget af det man lægger mærke til. Her får vi igen oplyst: Tracking Accuracy: 0.1436 arc second. Det er jo lidt morsomt og temmelig vildledende at skrive sådan. Det er formentlig encodernes opløsning det handler om.
          #89700
          webweichel
            En værdig kombatant in denne klasse må vel være IEQ45-V2
            Den er lettere har encodere og større dia. snekkedrev (såvidt jeg husker 5in i Ra).
            Er der nogen der har hørt om erfaringer med denne?
            #89702
            Astro Optics
              Citat: Bjørn T. Jønsson
              Jeg har ikke fundet flere oplysninger om denne montering end det som er nævnt i første indlæg. Har kikket hos OVL efter en manual, men der er ikke kommet nogen endnu.
              Sky-Watcher egen hjemmeside nævner ikke denne montering endnu
              Citat: Jesper
              Ja, det må næsten være encoderopløsning som menes.
              Mogens Zachariasen
              #89705
              holm
                Hmmm – den havde jeg ik’ set komme…
                #89711
                  Spændende, også muligheden for DSLR port og Alt-Az. Det ser vist ud til at blive den nye hype ligesom med Meade’s LX 80 multimount.
                  #89733
                    Tak for svar, Mogens. Den nye AZ-EQ6GT sejler nu op som et rimeligt alternativ for os der ikke har så meget penge.
                    Håndkontrollen kan skiftes ud med SynScan Tour, hvilket giver flere fordele som f.eks. stor skærm og større database. Også astrologi og spil(!) for dem der er interessert i det … samt mulighed for at fungere som en GPS.
                    Bjørn T. Jønsson2012-10-04 01:24:28
                    #89744
                    tomvictor
                      Sky-Watcher oppgir vel aldri maksimum PE på sine monteringer?
                      Tomvictor2012-10-04 11:38:00
                      Fornax Ligthtrack II
                      Tokina AT-X 300mm f 2.8
                      Canon 600D Baader
                    • Emnet 'Ny Sky-Watcher Montering' er lukket for nye svar.
