Travel Scope
Fora ASTRO-FORUM ER DU NYBEGYNDER? Travel Scope
  • Dette emne har 4 svar og 3 stemmer, og blev senest opdateret for 10 år, 5 måneder siden af avtar. This post has been viewed 42 times
  • #108483
    avtar
      I’m thinking of getting myself a travel scope for when I go away on holidays.
      It needs to be small enough so that it can be carried as hand luggage on a plane.
      Has anyone any suggestions?
      Avtar
      #108496
      helgeras
        One possibility is the Atrotrac.
        See : astrotrac.com
        I am probably going to buy this variant from TS: Photo mount Astrotrac
        This version uses a photo tripod soon for travel and fast setup. It won’t carry a scope I think, but it will make it possible to use a camera with a good lens.
        The more expensive mount they have on the web case (Astrotrac Travel System) seems to be a good choice for travelling, but it is probably not the cheapest solution available.
        And then you have to get a telescope too 🙂
        Regards,
        Helgehelgeras2013-10-09 21:57:16
        #108502
        avtar
          Hello Helge, thanks for your suggestion.
          I was thinking about getting a refractor telescope that would fit onto an ordinary photo-tripod.
          Possibly 70mm f6 that could fit into a flight bag with a few accories
          I would put the tripod in with the hold luggage.
          Regards
          Avtar
          #108516
            Many 80 mm f/6 and smaller refractors can be bought with a small suitcase which is airline cabin friendly. The mount is likely not as delicate, so you could ship that with your regular suitcase.
            There is also something like the Meade ETX series.
            #108527
            avtar
              Hi Madsen, thanks for the suggestion, I will have a look at the Meade ETX series.
              Reagrds
              Avtar
            • Emnet 'Travel Scope' er lukket for nye svar.
