Spektrum Planetarisk stjernetåge 150 år efter….
Fora ASTRO-FORUM OBSERVATIONER OG VISUEL ASTRONOMI Spektrum Planetarisk stjernetåge 150 år efter….
  • Dette emne har 4 svar og 3 stemmer, og blev senest opdateret for 9 år, 6 måneder siden af nightsky. This post has been viewed 55 times
  • #121371
      For 150 år siden d. 29. August 1864 blev spektret fra en planetarisk stjernetåge for første
      gang observeret af Sir William Huggins, objektet var Cat’s Eye Nebula, NGC 6543. I denne
      anledning har der været opfordringer til at lave spektroskopi på denne planetariske tåge,
      så derfor lavede jeg en optagelse forleden.
      I 1864 så Sir William Huggins tre emissionslinjer i spektret, en blå linje som blev identificeret
      som brint og to grønne linjer som ikke var set før. Astronomerne mente det var nyt stof som
      de kaldte ”nebulium” og først i 1926 blev linjerne identificeret som ilt. Man fandt ud af disse
      ”forbudte” ilt emissionslinjer kun kunne opstå under ekstrem lav tryk og høje temperaturer.
      On the evening of the 29th of August, 1864, I directed the telescope for the first time to a
      planetary nebula in Draco [NGC 6543, popularly known today as the Cat’s Eye]. The reader may
      now be able to picture to himself to some extent the feeling of excited suspense, mingled with a
      degree of awe, with which, after a few moments of hesitation, I put my eye to the
      spectroscope. Was I not about to look into a secret place of creation? I looked into the
      spectroscope. No spectrum such as I expected! A single bright line only! At first, I suspected
      some displacement of the prism, and that I was looking at a reflection of the illuminated slit
      from one of its faces. This thought was scarcely more than momentary; then the true
      interpretation flashed upon me. The light of the nebula was monochromatic, and so, unlike any
      other light I had as yet subjected to prismatic examination, could not be extended out to form a
      complete spectrum. . . . The riddle of the nebulae was solved. The answer, which had come to
      us in the light itself, read: Not an aggregation of stars, but a luminous gas.
      [W. Huggins, “The New Astronomy: A Personal Retrospect,” Nineteenth Century, 41 (1897), pp. 916-17.]
      http://www.jstor.org/stable/108876?origin=JSTOR-pdf
      Nedenfor optagelse – den monokrome og en kunstig farvelagt.
      Lidt mere info:
      William Herschel var den første til at bruge
      betegnelsen planetarisk stjernetåge og den
      første var Saturn
      stjernetågen, NGC 7009. Den første central stjerne fandt han i Cat’s Eye
      nebula, NGC 6543, og han troede at han opdaget en stjerne som var ved
      at blive dannet af
      den omkringliggende stjernetåge. Sidenhen viste det
      sig at det var omvendt, stjernetågen
      er kastet ud fra en døende stjerne.
      Nightsky2014-09-06 01:44:48
      #121377
        Super jubilæum reminder Lars. Har du indentificeret alle linjer?
        mvh Viggo
        #121379
        Mogens.Bildsøe
          Hej Lars, flotflot spektrum- er det optaget med dit nye spektroskop?
          Undrer mig lidt over,at 1.ordens spektret har et langt kraftigere signal end 0. ordens spektret? Hvordan er din grading “blazed”?
          Spektret viser jo også signal fra centralstjernen!! Evt. en profil af spektret?
          Kender du mag af centralstjernen og hvordan har du optaget billedet (ekspo, antal subs m.m)?Mogens B2014-09-06 11:40:21
          #121393
            Hejsa
            Mogens, helt normalt at 0 orden er svagere end 1 order. Optagelsen er med SA, 50×30 sek. subs, brændvidde 1525mm.
            Mener central stjernen er omkring mag. 11 – en O7 (WR) type – hvilket nogenlunde også skinner igennem på spektret.
            Viggo, jeps alle linjer er kendte.
            #121456
              Viggo, her er et forsøg på at bestemme nogle af de kraftigste linjer – nede i det blå områder
              bliver det rigtig svært med denne opløsning.
              Mogens, her er den rå stak vist lineært – som det ses er der meget stort forskel på flux
            • Emnet 'Spektrum Planetarisk stjernetåge 150 år efter….' er lukket for nye svar.
