Pluto okkulterer en stjerne den 14. juli
Fora ASTRO-FORUM OBSERVATIONER OG VISUEL ASTRONOMI Pluto okkulterer en stjerne den 14. juli
  • Dette emne har 13 svar og 4 stemmer, og blev senest opdateret for 7 år, 7 måneder siden af clauskaf. This post has been viewed 108 times
  • #148521
      Her er en “tester” til sommerhimlen:
      PLUTO OCCULTS UCAC4 345-180583 ON 2016 JULY 14, 0105-0115UT
      Tim Haymes:
      The international group led by Bruno Sicardy (Université Pierre et Marie
      Curie & Observatoire de Paris ), requests monitoring of this occultation
      which is reasonably well presented for UK and Europe. Details and finder
      charts are available on the IOTA-ES web site prepared by W.Beisker.
      http://www.iota-es.de/pluto-19072016.html
      The objective of the July 13/14 observation call, is to improve the
      astrometry for another Pluto occultation on July 19. The July 14 event is
      referred to as the “Path finder”.
      The star is 16.1 magnitude, and Pluto is 13.8. A small magnitude drop
      (0.3) should be detectable by amateur instruments with exposure
      (integration) times of 1 to 10 second.
      B.Sicardy’s Group wishes that as many people as possible will survey this
      seemingly more difficult occultation in the night of July 13-14, around
      01:12
      A summary of the July 13/14 event:
      The nearest bright star is pi Sgr – useful for syncing GOTOs
      Altitude 15 degrees ( Southern UK )
      Azimuth 200
      degrees
      Central time of the occultation : 0112 UT
      Predicted occultation duration : about 1 min
      Suggested period of continuous observation recording 0105-0115 UT
      Suggested exposure time (Video or CCD) 1 to 10 sec
      ( optimum will depends on detector, aperture and sky conditions )
      Video users – adjust the gain to a lower setting if using longer exposures.
      UT timing (e.g. PC clock) is relaxed. +/- 1 sec or better.
      The Star+Pluto combined magnitude (R) 13.8
      Magnitude drop during an occultation 0.3
      Advisory: Attempt a pre-run if possible, to check that Pluto has good
      s/n
      Reporting: Please read the paragraph “If you get a light-curve” in the link
      above, and send result to:
      Erick Meza <erick.meza@obspm.fr>
      Bruno Sicardy <bruno.sicardy@obspm.fr>
      Richard Miles rmiles@baa.u-net.com
      Tim Haymes tvh.observatory@btinternet.com
      Mark Kidger mrkidger@hotmail.com
        Ja man burde jo prøve:
        Men den befinder sig kun 6-7 grader over horisonten hmm man får dog ca. 2 timer før en anden stjerne af tilsvarende størrelsesklasse at øve sig på.
        Jeg har heller ikke noget kamera…..Ja der er mange undskyldninger for at komme tidligere i seng Men jeg har aldrig med sikkerhed set Pluto visuelt….
        Hilsen Claus
        #148572
          For at kunne se Pluto 6° – 7° over horisonten, gennem vores generelt temmelig disede luft, kræves et ret så kraftigt teleskop, da Pluto kun er mag. 14 og lyset dæmpes omtrent to størrelsesklasser i den højde…
            Hej Thomas
            Ja jeg ved godt at det nok er noget optimistisk, men måske jeg kan danne mig et indtryk 2 timer tidligere og så gå skuffet i seng…
            #148575
              Ja desværre ser mulighederne ikke så godt ud for dig Thomas, for hækken mod sydvest er vel ikke noget problem?
              #148577
                Lavest mulige horisont kan jeg altid skaffe mig, det er blot et spørgsmål om at smide teleskopet i bilen og køre ned til havet i den ønskede retning. At så finde et egnet sted uden lysforurening er straks en anden historie…
                  Således så Mars ud hos mig 5/5-2016 da den stod ca 10° over horisonten. Retningen var ca SSØ hvilket er hen over Svendborg Sund, Tåsinge, Storebælt og Femernbælt.
                  [TUBE]jLgD9GcUkYU[/TUBE]
                  Det så helt psykedelisk ud og gik fra det viste til en meget rolig Mars på ganske få minutter.
                    Ja jeg kan jo nok se at det virker håbløst…..
                    #148584
                      Håbløst er det ikke, men særdeles udfordrende, ja.
                        Sidder og kikker på Månen, Mars og Saturn i dagslys! Billeder følger senere. Seeing ser faktisk godt ud. Men jeg kan ikke finde Pluto uden stjerner. Mars og Saturn blev fundet ved at syncke Skychart på Månen, slewe ca hen til planeten og så spirale med EQMOD med slewrate 1 indtil planeten er i søgekikkerten. Endnu for lyst til at de kan ses med det blotte øje.
                          Jeg plejer at sætte min Evolution GRUNDIGT i vater, lave en solar system align på solen(solfilter) og derefter finder den nemt Jupiter mars (saturn) og de klareste stjerner på daghimlen
                          #148590
                            OK, det kan jeg ikke med min gamle EQ-5. Desuden er hovedet senest polalignet nede ved Napoli, så jeg satte latitude skruen efter den grove skala på siden, men overraskende nok drev planeterne ikke særlig meget da de først var centrerede.
                            Er der nogen der fanger okkulationen? Jeg opgiver deepsky og projektet i dag, desværre er det for lyst til at jeg kan nå blive ordentligt klar.
                              Noget tyder på at det er ved at blive overskyet her på trods af vejrudsigt
                              #148594
                                Selom det klarede lidt op, så må jeg opgive…suk!…Jeg fandt feltet og kunne se de klareste stjerner men Pluto – ja den er der, men jeg kan ikke se den
                              • Emnet 'Pluto okkulterer en stjerne den 14. juli' er lukket for nye svar.
