NASA’s Parker Solar Probe is About to Lift Off
Fora ASTRO-FORUM NYT FRA VIDENSKABEN NASA’s Parker Solar Probe is About to Lift Off
Tagget:
  • Dette emne har 6 svar og 1 stemme, og blev senest opdateret for 5 år, 6 måneder siden af Bjarne. This post has been viewed 515 times
  • #318884
    Bjarne
      https://www.nasa.gov/feature/goddard/2018/nasa-s-parker-solar-probe-is-about-to-lift-off
      At 3:33 a.m. EDT on Aug. 11, while most of the U.S. is asleep, NASA’s Kennedy Space Center in Florida will be abuzz with excitement. At that moment, NASA’s Parker Solar Probe, the agency’s historic mission to touch the Sun, will have its first opportunity to lift off.
      Launching from Cape Canaveral Air Force Station in Florida, Parker Solar Probe will make its journey all the way to the Sun’s atmosphere, or corona — closer to the Sun than any spacecraft in history.
      “Eight long years of hard work by countless engineers and scientists is finally paying off,” said Adam Szabo, the mission scientist for Parker Solar Probe at NASA’s Goddard Space Flight Center in Greenbelt, Maryland.
      Nestled atop a United Launch Alliance Delta IV Heavy — one of the world’s most powerful rockets — with a third stage added, Parker Solar Probe will blast off toward the Sun with a whopping 55 times more energy than is required to reach Mars. About the size of a small car, it weighs a mere 1,400 pounds.
      Parker Solar Probe is also the first NASA mission to be named after a living individual: Dr. Eugene Parker, famed solar physicist who in 1958 first predicted the existence of the solar wind, the stream of charged particles and magnetic fields that flow continuously from the Sun, bathing Earth. The spacecraft’s path through the corona allows it to observe the acceleration of the very solar wind that Parker predicted, right as it makes a critical transition from slower than the speed of sound to faster than it.
      #318887
      Bjarne
        Opsendelsen er aflyst lørdag. Man forsøger igen søndag. Årsagen er ikke kendt, men tiden løb ud.
        #318888
        Bjarne
          Stephen Clark:
          The Delta 4-Heavy’s countdown was halted at T-minus 1 minute, 55 seconds, as a member of the launch team announced a gaseous helium regulator alarm. No further details on the nature of the issue have been released at this time.
          #318892
          Bjarne
            Parker er opsendt og solpanelerne er foldet ud.
            #318893
            Bjarne
              Jeg har for de interesserede gemt en en relativ lang nyhedsartikel om the Parker Solar Probe på min blog:
              https://www.kosmologi.eu/wordpress/?p=4038
              Jeg har ikke oversat den til dansk, da den er semipopulær (ikke specielt beregnet for astronomer). Jeg har endnu ikke set en artikel om Parker på dansk.
              #318894
              Bjarne
                Helle og Henrik Stub har tidligere skrevet en artikel, som nu er blevet opdateret og ført til forsiden af videnskab.dk (den var der ikke lørdag):
                https://videnskab.dk/teknologi-innovation/kan-nasa-roere-ved-solen
                Opdatering 12. august kl. 9.45: Efter NASA aflyste lørdagens opsendelse på grund af et teknisk problem, gik det anderledes glat søndag morgen, hvor Parker-rumsonden blev opsendt helt efter planen. Rumsonden er nu på sin lange, varme vej mod Solen.
                #318895
                Bjarne
                  Tænk. Jeg har overset Jørgens udtalelser til ing.dk
                  »Og det er jo vigtigt at vide. For et større udbrud kan jo virkelig give problemer med strømforsyning og ødelagte satellitter. Vi har været meget heldige de seneste 20 år, at er ikke er sket mere hernede, da der jævnligt sker udbrud med retning mod Jorden,« siger Jørgen Christensen-Dalsgaard, professor på Institut for Fysik og Astronomi ved Aarhus Universitet og leder af Center for Stellar Astrofysik under Danmarks Grundforskningsfond, og fortsætter:
                  »Kan vi forudsige solstormene, ved vi også, om vi skal hente udsatte astronauter ned, eller om vi skal sætte satellitter i hviletilstand imens for at beskytte dem,« siger han.
                  https://ing.dk/artikel/varm-rejse-loerdag-saetter-nasa-kurs-mod-solen-213695
                  Syv gange rundt om Venus
                  Ifølge Nasas egen plan når vi hen til den 19. december 2024, før sonden er helt ’tæt’ på Solen. Undervejs vil sonden komme forbi Venus syv gange for at udnytte planetens tyngdekraft i en række slingshot-manøvrer – første gang d. 28. september, hvis alt går efter planen.
                  Men allerede om få uger bliver det spændende at følge sonden, understreger Jørgen Christensen-Dalsgaard.
                  »Data bliver sådan set spændende fra dag 1, eller i hvert fald fra første tætte passage i november, som kommer langt tættere på Solen end nogen tidligere mission. Sonden vil hele tiden bevæge sig ind i områder, vi ikke har studeret før,« siger han.
                  Læs mere i artiklen om magnetfeltets betydning for overførsel af energi til koronaen.
