Horsehead Nebula
Fora ASTRO-FORUM ASTROFOTOS OG -TEGNINGER Horsehead Nebula
  • Dette emne har 4 svar og 3 stemmer, og blev senest opdateret for 1 år, 9 måneder siden af Torben Taustrup. This post has been viewed 695 times
  • #328627
    flemov
      Nu da vi har fået off-axis guider på vores nye Newton,
      er det blevet muligt at køre med lange eksponeringer – uden
      at feltet skrider og det er en fordel når man skyder svage objekter.
      Til denne udgave af Hestehovedtågen & Co.er der brugt eksponeringstider
      op til 800 sek.
      Der er brugt en del tid til afterbehandling – især til at fjerne satellitspor.
      Jeg synes egentlig at objekterne i venstre billedhalvdel også er interessante
      ligesom de svage strukturer der kan anes i dybet.
      Data: 14,5″ F:4,2 Newton – ASI2600 MM Pro.
      6x600sek luminans, 8x800sek. Halpha RGB a 6×600 sek.
      Link til fuld opløsning
      https://tocobs.org/toc/HorseHead/Horse_Deep_3.jpg
      Horse_Deep_3_MR
      Flemming
      Flemming R. Ovesen.
      TOC observatory
      https://tocobs.org
      Vedhæftninger:
      #328810
      SebaAstro
        Wonderful image!!!!
        I just moved to Aarhus from USA. I am thinking to build an observatory on my backyard. Any suggestion on local company supplying material to build it?
        I would be interested to hear from you and your experience.
        My equipment:
        imaging Telescopes Sky-Watcher Esprit 150 and Esprit 80
        Imaging Cameras QHY268M
        Mounts Sky-Watcher EQ6-R
        Filters Astrodon Ha 36mm 5nm · Astrodon Gen2 E-Series B – 36mm · Astrodon Gen2 E-Series G – 36mm · Astrodon Gen2 E-Series R – 36mm · Astrodon L 36mm Gen2 E-Series
        and most important: lots and lots of passion for Astrophotography, Astronomy, Physics and and Science in general!!!!!
        Frames:
        Astrodon Gen2 E-Series B – 36mm:
        Astrodon Gen2 E-Series G – 36mm:
        Astrodon Gen2 E-Series R – 36mm:
        Astrodon Ha 36mm 5nm:
        Astrodon OIII 36mm 5nm
        Astrodon SII 36mm 5nm
        Clear Sky,
        -Seba
        #328811
          Hi Seba
          Fine equipment you have there 🙂
          I’m not able to recommend a local company, as you do not state where your backyard i situated 😉
          You could choose to buy a dome like this, if you are prepared to build the rest of the observatory.
          https://explorescientificusa.com/products/pulsar-2-7m-short-height-observatory-dome
          What is your budget?
          #328812
          SebaAstro
            Hi Torben,
            Thanks for your reply and for the link.
            Sorry for missing the reference to my location: wet Aarhus DK, suburb (rural) area.
            Budget quite low: 3.000 euros. SO I am looking for a very basic observatory just to cover the equipment (i wish i had more funds for something bigger!)
            My Astrobin Link is: https://www.astrobin.com/users/sebaromano/
            -Seba
            #328820
              Hi Seba
              Check this:
              ATM – BYGGEPROJEKTER
              To avoid topic confusion as people will not search for observatory projects under Astrophoto 🙂
              Best regards
