Er det mon Draconid meteor shower vi ser?
Fora SEKTIONER I ASTRONOMISK SELSKAB Meteorsektionen Er det mon Draconid meteor shower vi ser?
  • Dette emne har 2 svar og 2 stemmer, og blev senest opdateret for 7 år, 5 måneder siden af henrik. This post has been viewed 435 timesschneider. This post has been viewed 435 times
  • #152063
      Det er da en sand sværm af stjerneskud der bliver fanget for tiden, se bare her de sidste nætter:
      Citat Earthsky
      “Everything you need to know: Draconid meteor shower
      By Bruce McClure and Deborah Byrd in ASTRONOMY ESSENTIALS | October 6, 2016
      The maximum number of Draconid meteors are expected to fall on the evening of October 7.
      October’s Draconid meteor shower – sometimes called the Giacobinids – radiates from the fiery mouth of the northern constellation Draco the Dragon. Because the radiant is located so far north on the sky’s dome, this shower favors temperate and far-northern latitudes, such as the U.S., Canada, Europe and northern Asia. In 2016, the peak dates will probably be on the evenings of October 7, starting at nightfall. There’s a rather wide waxing crescent moon to obscure this year’s shower. Yet this shower is oftentimes a sleeper, even in a dark sky completely free of moonlight. But watch out if the Dragon awakes, which is always a possibility! Follow the links below to learn more about the Draconid meteor shower.”
      http://earthsky.org/astronomy-essentials/everything-you-need-to-know-draconid-meteor-shower
      henrik.schneider2016-10-05 08:09:00
      #152069
      norup
        Ja, der var pænt gang i den her til morgen.
        For hver detektion er der angivet radiant og bane – umiddelbart synes der ikke at være ret meget systematik, der tyder på en bestemt sværm, og det passer ikke specielt godt med Draconide-radianten. Softwaren bør i øvrigt automatisk genkende Draconider – de er med i databasen.
        Så jeg ved ikke lige, hvad der sker…
        #152088
          Nej det gør jeg heller ikke Anton
          Spændende hvad der sker iaften/nat – over Hobro er der clear-sky
        • Emnet 'Er det mon Draconid meteor shower vi ser?' er lukket for nye svar.
