A Candidate z∼10 Galaxy Strongly Lensed into a Spatially Resolved Arc
The most distant galaxies known are at z~10-11, observed 400-500 Myr after the Big Bang. The few z~10-11 candidates discovered to date have been exceptionally small- barely resolved, if at all, by the Hubble Space Telescope. Here we present the discovery of SPT0615-JD, a fortuitous z~10 (zphot=9.9±0.6) galaxy candidate stretched into an arc over ~2.5″ by the effects of strong gravitational lensing. Discovered in the Reionization Lensing Cluster Survey (RELICS) Hubble Treasury program and companion S-RELICS Spitzer program, this candidate has a lensed H-band magnitude of 25.7±0.1 AB mag. With a magnification of μ~4-7 estimated from our lens models, the de-lensed intrinsic magnitude is 27.6±0.3 AB mag, and the half-light radius is re<0.8 kpc, both consistent with other z>9 candidates. The inferred stellar mass (log [M*/MSun]=9.7+0.7-0.5) and star formation rate (log [SFR/MSun yr-1]=1.3+0.2-0.3) indicate that this candidate is a typical star-forming galaxy on the z>6 SFR-M* relation. We note that three independent lens models predict two counterimages, at least one of which should be of a similar magnitude to the arc, but these counterimages are not yet detected. Counterimages would not be expected if the arc were at lower redshift. However, the only spectral energy distributions capable of fitting the Hubble and Spitzer photometry well at lower redshifts require unphysical combinations of z~2 galaxy properties. The unprecedented lensed size of this z~10 candidate offers the potential for the James Webb Space Telescope to study the geometric and kinematic properties of a galaxy observed 500 Myr after the Big Bang.
