› Fora › ASTRO-FORUM › ASTRONOMIENS BETINGELSER › Ansøgning af obs.tid på NOT
- Dette emne har 7 svar og 6 stemmer, og blev senest opdateret for 7 år, 4 måneder siden af jens. This post has been viewed 1025 timesjacobsen. This post has been viewed 1025 times
24. oktober 2016 kl. 17:43 #153042
Alle kan ansøge om observationstid på Nordic Optical Telescope, også amatører.
Så hvis du/i har et interessant obs. program i tankerne, så få det beskrevet og send en ansøgning. Det kan lade sig gøre, og det er sket førKan klart anbefales!
NOT har netop lagt denne meddelelse på deres facebook-side >>
The Nordic Optical Telescope invites applications for observing time in Period 55, April 1, 2017 – October 1, 2017
⏳ The deadline for receipt of the applications is Friday, November 18, 2016, at UT 12.00 noon. #ORMLaPalma
In relation to the call for proposals, the following:
✔️ Up to 8 extra nights of observing time are offered to proposals from researchers affiliated with Danish institutions.
New (e2v CCD231-42) detectors have been installed in ALFOSC and FIES.
The CCDs are deep depletion devices, with low-fringing and high
efficiency in the red.✔️
Together with our set of VPH grisms, the detector provides an overall
efficiency for ALFOSC which rivals that of similar instrument set-ups on
4-m class telescopes.✔️ The
new CCDs are about 10% larger than the previous ones. For FIES, this
allows to sample further into the infrared part of the echellogram, and
we now reach from 3700 to 9100 Ångstrom for the high-resolution fiber
(F4), while for the other fibers we sample a few hundreds of Ångstroms
less into the infrared. For the previous CCD the sampled range was
3700-7300 Ångstrom.✔️ A new
fibre bundle is planned to be installed in FIES before the start of
semester P55. With this new bundle, we expect the radial-velocity
stability with the high-resolution fiber to improve from 8-10 m/s to ~3
m/s.✔️ The SOFIN
high-resolution Echelle spectrograph is again available. It offers a
resolution of R=27000-170000, and it also offers spectropolarimetry.
SOFIN is not a common-user instrument: only limited support is provided.24. oktober 2016 kl. 17:53 #153043
Jeg vil lige kommentere at det stunt vi lavede i 2006 næppe vil ske igen. NOT er MEGET populært.
De er meget mere strikse i udvælgelsen af projekter der får tid.
Men man kan naturligvis prøve.
24. oktober 2016 kl. 18:05 #153044
Korrekt!
Men de skriver også, at antallet af ikke-europæiske ansøgere langt overstiger nordiske ansøgere, samt at disse langt overvejende ikke kan gengælde med tilsvarende ydelser, feks. obs. i andre lande.
Når jeg tager optimist-hatten på (den med propellen), så læser jeg det, som en klar opfordring til flere ansøgere fra de nordiske lande, og at disse måske beskues med lidt mildere øjne.Men der skal være en 100% klar beskrivelse af ansøgerens videnskabelige formål og hvordan den ansøgte observationsprogram bidrager til ny/bedre forståelse indenfor det specifikke felt det omhandler.
Så blyanten skal helt sikkert spidses! Men jeg synes ikke man skal lade sig skræmme! Det værste der kan ske er, at man får et afslag. Måske med en masse gode råd til sit næste forsøg.Citat fra deres web-side:
NB: The competition for observing time at the NOT is very
keen, and our small OPC cannot contain experts in all fields of
astronomy. Therefore, it is CRUCIAL that proposals outline
CLEARLY the scientific background and context of the proposed
project, and also explain
CLEARLY what contribution the planned observations will make to
advancing our understanding of the field in question!24. oktober 2016 kl. 18:28 #153045
Tror i, man kan komme lidt foran i køen, hvis man tager sine egne okularer med?
24. oktober 2016 kl. 19:52 #153053
Der er også den lille detalje at man skal være tilknyttet forskning ved et universitet for at kunne ansøge. (Dette blandt andet fordi der nu skal betales for observations tid. De danske universiteters tid er dog betalt)
Så der skal laves lidt lobby arbejde på forhånd hvus man som amatør skal have et projekt igennem.
24. oktober 2016 kl. 20:32 #153058
lindhardDeltager- Super Nova
Astrojensen wrote: Tror i, man kan komme lidt foran i køen, hvis man tager sine egne okularer med?
Du skal nok bruge 2″ okularer på den kikkert..
Lars24. oktober 2016 kl. 20:46 #153060
Lindhard wrote: Du skal nok bruge 2″ okularer på den kikkert..
Og sandsynligvis vil de ikke have kinalus på det fine teleskop, så ingen CE mærkede okularer
Nightsky 2016-10-24 21:05:32 24. oktober 2016 kl. 21:34 #153062
- Emnet 'Ansøgning af obs.tid på NOT' er lukket for nye svar.
