An Extreme Trans-Neptunian Object
Fora ASTRO-FORUM NYT FRA VIDENSKABEN An Extreme Trans-Neptunian Object
  • Dette emne har 2 svar og 2 stemmer, og blev senest opdateret for 5 år, 9 måneder siden af Bjarne. This post has been viewed 811 times
  • #317817
    Bjarne
      Discovery and Dynamical Analysis of an Extreme Trans-Neptunian Object with a High Orbital Inclination
      We report the discovery and dynamical analysis of 2015 BP519, an extreme Trans-Neptunian Object detected detected by the Dark Energy Survey at a heliocentric distance of 55 AU and absolute magnitude Hr= 4.3. The current orbit, determined from a 1110-day observational arc, has semi-major axis a≈ 450 AU, eccentricity e≈ 0.92 and inclination i≈ 54 degrees. With these orbital elements, 2015 BP519 is the most extreme TNO discovered to date, as quantified by the reduced Kozai action, which is is a conserved quantity at fixed semi-major axis a for axisymmetric perturbations. We discuss the orbital stability and evolution of this object in the context of the known Solar System, and find that 2015 BP519 displays rich dynamical behavior, including rapid diffusion in semi-major axis and more constrained variations in eccentricity and inclination. We also consider the long term orbital stability and evolutionary behavior within the context of the Planet Nine Hypothesis, and find that BP519 adds to the circumstantial evidence for the existence of this proposed new member of the Solar System, as it would represent the first member of the population of high-i, ϖ-shepherded TNOs.
      #317884
      astoft
        Interessant.
        Søren
        Søren Toft - Virum
        #317904
        Bjarne
          Ja. Den bidrager til argumenter om Planet Nine. Forbiflyvningen af Gliese 710 kan blive interessant i denne sammenhæng.
        • Emnet 'An Extreme Trans-Neptunian Object' er lukket for nye svar.
